Has anyone ever used these? I am thinking about one for my '04 PI GM. Stock single exhaust, AEM dryflow, and shortly a 180 stat. Not trying to set the world on fire, but I wouldn't mind a small power boost. I understand peak HP and everything else, but what I am interested in is torque and HP where you use it real world- 2500-3500 RPM, 1/2 to 8/10 throttle, merging, etc. Pretty much going to do a sway bar and maybe one performance mod. Any thoughts? Does it fit well? Any install issues?
C&L Plenum
C&L Plenum
2004 Mercury Grand Marquis LS
185 degree stat. 21mm rear swaybar with moog end links, Moog progressive rear springs.
JLT intake, B&M transmission pan, 2.25 inch duals, magnaflows, Powerstop drilled/slotted front rotors and ceramic pads. Kenwood Excelon deck, Kenwood 6x8 3-ways all the way around.Tags: None
I think your money will be better spent upgrading to Dual exhaust. then a Marauder air box/MAF and an SCT tune.
Chris at www.adtr.net has ported factory plenums that are less expensive and fit better than the C&L units.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Yeah, I am thinking about the duals. I was just thinking about the plenum as a quick and easy mod. Do the ported ones work as well as the new castings I tried his site and it's all jacked up. You can't look at products or order right now.2004 Mercury Grand Marquis LS
yeah, there appears to be a problem with the site. I emailed chris about it.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I saw Summit has trick flow plenums for a decent price too....I am one of those miserable bastards who war games everything 1,000 times before doing it.2004 Mercury Grand Marquis LS
