Originally posted by iphearbunnies
View Post
2001 grand marquis help
08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
It's easier to do that in the 03+ due to the change in the frame and power steering system. Yes, you can do the swap, but it just becomes more of a pain in the ass.
If I had $4500, I'd get a TorkTech kit; Mount an Eaton M122 supercharger on top and go from there.
I'd look into the TorkTech kit then.
Originally posted by iphearbunnies View Postim not looking to swap engines, i want to keep mine.
The formula to easy 13s NA with a 4.6 PI engine is pretty much cookie cutter. If you do cams, exhaust, converter, gears, MZT and tune you are easily there. You can probably do a throttle body and upper plenum for good measure. You can then bolt a wet N2O plate on there and put yourself in the 12s.
The HFS intake manifold has the bosses for a wet nitrous system. That, with the aforementioned, would be a sweet N/A setup.
or you could pull it and do a 460/c6 swap like me....
2001 Mercury Grand Marquis LS
Ram AIR,NGK V-Power Plugs, K&N, 3.73 posi, sct tuner, J-Mod, 75 mm Throttle Body & Plenium, 80 mm maf, Mercury Marauder Airbox, Homemade air tube, BBK Shorty's, X-pipe, High Flow cats, 2.5 inch exhaust, dynotune by HUTTER PERFORMANCE 236RWHP / 277TQ
LIFE'S JOURNEY IS NOT TO ARRIVE AT THE GRAVE SAFELY AND IN A WELL PRESERVED BODY, BUT RATHER, TO SKID IN SIDEWAYS, TOTALLY WORN OUT, SHOUTING “HOLY SHIT....WHAT A RIDE!"
