I'm starting to create a plan of attack for improving this car. I'm pretty conservative when it comes to such things - more a tweaker than customizer, I guess. Anyway, I'm considering a stock single to factory dual upgrade. 2", and I don't want to get into the relative merits of different pipe diameters, thanks, there is plenty of that debate for everybody in the "other" thread on this subject. I figure factory dual is a good, cost-effective way to make a small improvement in engine respiration and economy. My main question centers on that last assumption. I've read that factory single to factory dual in this car is worth about 11HP. Now, in my yoot, on carbureted, non-computerized cars, that would have also equated to a slight increase in MPG, with the variable being the scale of carb rejetting, if any. I'm not sure how that plays out with PCM tech. Would I see a (SWAG) 1 - 2 MPG increase, or would the 'puter just "see" the restriction reduction and perform the equivalent of rejetting by richening my A/F mixture accordingly? If that is how it works, is there a potential change in programming that could "redirect" some of the breathing improvement to better mileage, and what would that cost me? Second question - do I assume correctly that this conversion requires an additional rear cat, and if so is it included in the Ford parts assembly for this job? Thanks.
-VG
-VG
