Is there anyone with info on the net who has put a small block or a big block in a 2003+? I am not worried about motor mounts as I will do custom in order to drop the motor down low for hood clearance....
2003+ Pushrod Motor Header & Oil Pan Fit?
Originally posted by Mercracer View PostIs there anyone with info on the net who has put a small block or a big block in a 2003+? I am not worried about motor mounts as I will do custom in order to drop the motor down low for hood clearance....
Originally posted by 86VickyLX View PostI'm about 85% sure the hood, at least the fenders are the same... you should be able to use box engine mounts (if you're doing a 302/351w swap)
Originally posted by Tom View PostI'd research ford-trucks.com, I think a few people over there have put pushrod motors in trucks with the crown vic IFS.
Other than that, what's the issue?
Originally posted by Tom View PostWell, I am not sure on headers/oilpan.
I do know motor mounts would be really simple to make. I have a complete 04 CVPI front suspension in my garage, I can take photos if you'd like.
