Anyone elses gas pedal seem really stiff until it starts moving, and then it sinks to the floor easily? The spring on my throttle body seems to be in good shape but for some reason the pedal feels super stiff at first and you have to use extra pressure. Then immediately the resistance is gone and you take off way too fast. This is making quicker take offs like on highways really uneven and cornering while having to use the gas sucks. Anyone hear of this or have a solution for it? Car's a 94 ls.
Sticky gas pedal
Thanks for the quick response, I probably should have mentioned I tried cleaning that sorry lol. I figured that's what it was at first so I wiped it down but it wasn't very dirty at all. I'm scared to spray carb cleaner in there because it has that sticker saying it will eat away at the lining in it. I also sprayed the linkage with some wd to see if it made any difference and nothing.
Originally posted by JerseyTrueBlue View PostI was wondering if it was a model thing and not just my car. You say you can't get carb cleaner, but I have a can. Does this mean it would be safe to use on the throttle coating since it's not as rough?
