1) 2003 MGM single to dual exhaust conversion was the question, not '79-'91 anything else. I do all my own work and have never been to an exhaust shop. I ordered... wait for it... the CORRECT PARTS for my install.
2) 2 x 2 = 4" of exhaust output. On the intake side we have, 3". Its a pump. Flows must balance. I have seen Mustangs with flattened exhaust components with large systems. Speed bumps, driveways, curbs ect.
3) I have detailed timed 0-60 runs on every modification I have done to the '09. Filter and exhaust were first, and good for a .6 second drop in 0-60 times. This is the Walker direct replacement CVPI exhaust. Not a performance system. I had less than an 1" clearance on the fuel lines, and emergency brake cables. I spent a good bit of time underneath, so I am not guessing here.
4) I don't know you either and do not see your gratitude. I can interpret anything the way I want. Someone asked a question and I answered with part numbers that I used. If there had been a terrific Mustang cross reference substitute, a nice X-Pipe maybe, I would have noticed it somewhere and ordered it. You are the one, not ever having worked on the later model, assumed that I did not know what I was talking about.
