Nobody's addressed the fact that this would drastically lower the already low compression ratio, that's why 2V heads make 12:1 on a 4V bottom end.
Mark Viii heads/intake swap on my NPI shortblock...why not??
Originally posted by v8only View Posti'm not set on a 4v swap. for now I'm going to try the PI swap. I also read that swapping the 4v heads on a 2v pre 99 engine will result in 8.5 to 1 compression..not good unless I run a blower...
just continuing the discussion, anyone know about the 05+ 3v motors?
03 Mercury Marauder- 63k
I stand corrected and apparently can't read. 8.5:1 isn't as horrible as what I was thinking.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
No. But it's prime for a blower or forced induction of some kind. I would run too much boost without some internal upgrades.
