.... Yes you can.
I was told the MM air box wouldn't bolt into my 2003 Town Car with out some modifications. Appearantly, the Town Cars, at least the older models, pulled air from the bottom of the air box instead of from the front, behind the headlight. Of course I had to investigate this and found my car used the normal CV/MGM set up and pulled air through the dinky air snorkel behind the drivers headlight. build date on my car is 5/2003
I located a Used MM air box on eBay, bought it and installed it with little problems. Turned out the seller on eBay was a CVN member (thanks Steve_83).
The Marauder air box fit almost perfectly. the only issue I ran into was the rubber air intake hose for the air suspension pump. it was orginally routed around the front air snorkel on the stock air box, but since the Marauder air box has a much larger snorkel I had to modify the front mounting tab on the air box slightly to eliminate the hose from kinking. other than that it bolted in the car with no fitment issues.
Quick Before and After shots;
So, the parts are installed... waiting on my Tune from Lonnie.
:3gears:
:3gears:
