dohc 4.6 engine swap
    Find great deals on new and used cars and trucks with Kijiji Autos: thousands of great cars for city driving, families, luxury, fun and more!
    Can the dohc 4.6 from a FWD Continental be swapped into a Panther?
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    Im pretty sure you can
      isnt that a fwd bellhousing 4.6?
      use a mk8 engine
        Thanks for your input guys.
        '94 Crown Victoria
          The ad lists that the idler arm has been replaced and the frame is broke. Sure it isn't a SOHC TC? Sure doesn't sould like a FWD Conti to me.
            seller could be wrong
            My Grandparents live in McAdam, NB. I'll swing by and check the car out next time I go for a visit. An hour & a half drive from my location.
            '94 Crown Victoria
              conti's are FWD 32v WILL NOT bolt to aode/4r70w. different bellhousing and bolt pattern.
              go with the mk8.
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                I dont know why but I was thinking mk8, my bad, thats why I said "pretty sure"
                  The ohc 4.6 in my '92 CV runs well but a dohc 4.6 would rock...
                  '94 Crown Victoria
                    much better...
                    '98 Mark VIII
                    '94 Crown Victoria
                      Originally posted by 79lincolnlover View Post
                      .....but a dohc 4.6 would rock...
                      It's not a bad engine....but it costs about 3 times as much to modify vs. a 302/351W, and is pointless unless you supercharge it.
                      Oh well, call me picky.
                        Just tossing this out there:
                        I had a 351 box and an MK8 at the same time. Both geared virtually the same, with the box a couple of hundred pounds lighter. Anytime I got into the MK8 it felt like I was towing a trailer or had the e-brake on. Although it would be cool to have a box with the 32V 4.6 I wouldn't do it for the performance.
                          I think that if I already owned all of the necessary parts....I might consider the swap. But at this point, I think it's more feasible to do a 460 swap than to do a 4.6 DOHC engine install.
                            I think I would do a pi conversion, maybe some cams before I did that 4v swap. the converted 2v would make the same hp with more bottom end. if thats not enough, add boost
                              Seemed the huge heads on the 32V 4.6 wanted to occupy the same space as a box's UCAs when I pulled the tape out. A 2V would clear no problem.
