I actually like the dry stuff, especially in a plastic intake with 180 degree turns. but alot of people love the wet stuff. you wont have to worry about n2o backfires in a dry setup, also pretty much any dry kit that uses the fuel pressure regulator for enrichment, your enrichment is in proportion to bottle psi
NO2 on 97 4.6L??
Sorry!! to avoid confusion of any sort i bought a spare headlight and i took a heat gun to the adhesive and popped off the lens and took my die grinder with a porting piece on it and made the hole bigger which draws air directly into the filter of the after market intake. I have originally place a cold air box but had terrible luck and this method had seemed to work better for higher rates of speed and in daylight actually gave me 2MPG more!! which i was excited about.
