Ok I got a 93 marq I'm looking to upgrade the suspension and rear end asap. I would like a nice stiff ride with a good hot rod stance/rake. I drive the car every day the air struts are shot and the ride feels sloppy as hell I'm used to sport compact cars. I have a set of 18s that will be going on in spring so I'd like to have this stuff done before then. Will all the rear ends swap or only certain ones what years should I look for I'd like to have both tires spinning but don't want to lose the mpg. Thanks guys I will have a lot more questions after this stuff is done.
93 grand marquis junk yard upgrades?
93 grand marquis ls = the daily
97 dodge neon GLH-4 = the project -
big front brakes from a 98-02 panther....u will need spindles, rotors, hub bearings, caliper brackets, calipers and hoses oh and you need at least 16" wheels for the front.
99-02 police steering box
police sway bars
that's all i can think of for now to harvest from the yards
as far as new stuff goes, the idler and pitman arm are prob shot as with most panthers i work on for the first time
get 4 new shocks.......for the money i like the kyb gr2 shocks for a police interceptor
poly bushings are available for the front suspension, rear suspension and the body to frame mounts
Trac-loc (posi) rear-ends. Mine cost $24 bucks from the junkyard. i had the option for 3.55's on it but i took them off.
03 Mercury Marauder- 63k
ok
so 1st im getting the shocks and springs like next weekend i want to get the kyb gr2 for the police interceptor but what year do i get. and springs i'd like to get the cargo wagon but will they fit and what else will i need to do the swap to the spring as i got the air spring. thanks
and on the rear end can i just swap the complete rear like axle and all or is it easier to swap just the diff and gearLast edited by RAMSMARQ; 02-21-2010, 12:58 AM.93 grand marquis ls = the daily
Swapping the differential and gears is easier than swapping the axle.
For the suspension, I don't know. But I'm sure the guys in the Drivetrain/Suspension forum could hook you up.
x2 on kyb shocks, my 2nd choice would be monroe sensatrac, but the kybs are better imho
x2 on sway bars
from a performance perspective,if your are good with motors, I would grab a pi intake and some pi cams; the heads arent as important, just swapping cams is pretty easy on a 4.6, if you already have the intake off, I would consider doing heads, but the power is in the intake and cams.
find a tracloc and if you can find a an aerostar, alot of them come with a 4.10gear, if not, some rangers and even fewer explorers have a 3.73; the rest of the rangers/exploders are mostly 3.55's. note- just make sure your donor vehicle is an 8.8 differential,its pretty obvious just by looking at it
convert to dual exhaust for sure with some free flowing mufflers. the dynamax super turbos flow pretty good while still keeping the noise downLast edited by jayh; 03-04-2010, 10:53 AM.
valving is different on the cop shocks, usually somewhat heavier. from the factory, the cop cars got stiffer shocks to go with the stiffer springs.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postvalving is different on the cop shocks, usually somewhat heavier. from the factory, the cop cars got stiffer shocks to go with the stiffer springs.
the gas a justs are what you want for a firmer ride......the gr2's are a low cost replacement shock. the fronts for the cop cars have a larger bore.....the cop rears were discontinued, the rear really dont make a difference in shocks
Originally posted by Lincolnmania View Postthe gas a justs are what you want for a firmer ride......the gr2's are a low cost replacement shock. the fronts for the cop cars have a larger bore.....the cop rears were discontinued, the rear really dont make a difference in shocks
I really like the gas-a-justs on my 97 G.M.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
