Originally posted by TomO
View Post
My vic is too slow
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by Nathan in MI View PostIt's not the same size motor. The Mark VIII and Marauder used the dual overhead cam V8, whereas the Panthers use the single overhead cam engine. The DOHC is physically larger, and far from a bolt-in swap.2012 Mazda5 Touring | Finally working on the LTD again!
My favorite car show question is
"That's a 460, isn't it?"
"Nope, 281"
"That's it?"
"That's it"08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
Originally posted by p71towny View PostNot on a 4.6. Just sounds wierd IMHO.
If you want it to sound good cheaply stay away from magnaflows and flowmasters. Mags sound good, I dont like the sound of flows, and either way have fun spending around $150 for a pair.
And damn if I had $2600 i'd have a turbo Grand Marq.
Ik from the get go that I wouldn't have a superfast car. But it's like a ferrari compared to my old Volvo 240 and current 1985 VW Vanagon...
The way I plan on gettin a bit more speed. Is 3.55 gears (instead of my 2.73), programer, PI manifold/intake, and throttle body. Ik it wont be much, but it will be some... All I need is the money...1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
1985 VW Vanagon 70k~
the 4.6 bastard block was used with an aod only until march 1992 in the 91-92 town car and the 92 grand marquis/crown vic........no such thing as a bastard block 32v engine
Originally posted by Lincolnmania View Postthe 4.6 bastard block was used with an aod only until march 1992 in the 91-92 town car and the 92 grand marquis/crown vic........no such thing as a bastard block 32v engine2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostSo then what did they put in the Lincoln Mark VIII that ViperGTS was able to bolt a regular AOD up to?1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
Originally posted by DriverSideImpact98 View PostYou can get trans adaptors for anything. I think you can even get an adaptor to hook a Cummins diesel to a TH350 trans. So I'm sure a Mod to AOD isn't hard to find.2012 Mazda5 Touring | Finally working on the LTD again!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by Briglad View PostYou can put a Viper engine in nearly anything...
Originally posted by 1987cp View PostTrue, true ... I'd have to check with torquelover again, but I'm pretty sure ViperGTS bolted his right up.
This was slightly comical as the trans somewhat negated the 3.73 RAR that was installed just prior to the 3rd trans swap.
