PI heads on Lincoln MK8 bottom end
    At the risk of hijacking the thread just slightly, what's changed about the cams between '95 and '96?
      Why in particular must the vehicle remain SOHC?
        I would have to assume if its going in some type of race car that it is regulations limited to be a SOHC. Are you carburating it? Or do the regulations not require that?
        1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
        1985 VW Vanagon 70k~
          Originally posted by theredlineboss View Post
          Do you mean the cams from a 93 lincoln town car? If so, the cams should be the same from 91-95. If you are referring to the Mark VIII, then...well, you are just being silly. :p
          -Rob
          SOHC town car not DOHC MK8
            You are correct, it is a race car and must stay SOHC and it will be fuel injected.
              Its going to be hard to find specs for stock pistons..You might want to find an older single cam 4.6 and swap a set of PI SOHC heads to bump up the compression.
              R.I.P Linsey Nelson
