I have a 2000 GM with single exhaust now i was thinking about getting this exhaust but it says its only for 06/07 crown vics. Should i be able to bolt this system up to my car cause it looks like just a normal single to duel pipe conversion am i right?http://www.adtr.net/shop.php?page=exhaust
ADTR.net Magnaflow cat back system
Any exhaust shop should be able to custom build the exhaust to the way you want it... muffler choice, x or h pipe, even pipe size... and you don't wanna do single to dual. You'll want true duals since there are two pipes running off the motor.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
The Panther chassis was re-designed in '03, so I'm not sure what problems that would cause with installation on a pre-'03 model.
You should be able to get parts for dual exhaust from any parts store. You'll need to get the body mounts for the hangers from Ford or a bone-yard, but everything else is available after market.
RayCar: 2004 Mercury Marauder
Engine/Tranny: 49k miles and bone stock....for now
Anymore cutting off the cats cause more problems than the power that they gain..Unless your building a full race car there is no need to do away with the cats all together...If anything just run a set of high flow catsR.I.P Linsey Nelson
Originally posted by MeanVic84Chocolate Rain. Some stay dry and others feel the pain.
