This may be a stupid question but I was wondering if there was a way to run a low boost turbo (6-8 LBS) on a 4.6?? A bunch of honduh guys I work with say it can be done...I was thinking about using a turbo out of an old supercoupe and doing a custom system
Turbo M75
good luck finding room......the 4.6 is big
yes, there are a few turbocharged panthers running around.
Super coupe= SUPERCHARGED
TURBO COUPE= Turbo. And that is WAY too friggin small for a V8... you would need 2.Builder/Owner of Badass Panther Wagons
That could be fun. In theory I think it should be possible to turbocharge most any engine as long as the innards are up to it (i.e. I wouldn't want to run much boost without forged pistons). I'd think as long as the turbo size is well thought-out (big enough to make the power you want but small enough that lag is acceptable) and you run an intercooler and an appropriate custom fuel map to optimize power and avoid exciting smoke shows in the wrong place, the results could be a huge amount of fun.2012 Mazda5 Touring | Finally working on the LTD again!
huh, we'll have to get someone on this thread who really knows about turbos....
I'd guess these would be good places to start:
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by mrltd View PostPretty much everything has been answered. Search a bunch before posting makes life easier for everyone. Also you can learn a lot.
Concerning the turbo on the 4.6? Is the engine stock? Don't bother, the motor won't handle it. The earlier 4.6 2V engines are weak, bad head gaskets to start with....the pistons are usually the next culprit.
Just use the 5.4 triton swap on this page:
Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
This is what the car is needing, actual low-end grunt.
