Will 1992-1994 Cats Fit 1995-1997?
    The title says it all, will they physically bolt up or are they different?
    The cats will bolt up... but you will have to add bungs for the rear o2 sensors.
      last question, how about 2003-2011 cats, will they bolt up...if so, whats the difference?
        yes and no... 03+ has a subframe up front that makes the angles and bends a little different. I think things will still bolt up, but because of different bends... the 03+ will hang quite a bit lower and possibly drag the ground. Sticking with 92-02 range is the best bet for having things fit. 95-02 for direct fit.
