regardless it will fit on that engine right?
2000 P71 Im about to buy.
well it isn't a direct bolt on replacement, so a typical maintenance shop wouldn't do it.
maybe someone else can chime in who knows where you could have someone do that kind of work.2000 Mercury Grand Marquis LS HPP.
http://www.cardomain.com/ride/2336322
Friends don't let friends drive donk.
Originally posted by BigTomZunfortunately it seems like you have to get in there and look, at which point you are already into the project. so it is better to just buy one to have on hand since they aren't too expensive.
Again the PI parts is cheap. What is so different about the two? Is one more desireable than the other?My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
the PI manifold will fit. it requires a little extra work, but it does fit and is worth having.
mercenvy is right actually you should be able to see the cooland nipple after removing the alternator.
the PI intake manifold will give you 15 more horsepower on a non-PI motor. the PI cams will also add 15 more horsepower. they will also expand your powerband more into the higher rpm. the combo will hurt your low rpm torque slightly, but you'll probably still run a good half second faster in the 1/4 mile.2000 Mercury Grand Marquis LS HPP.
mercenvy is right actually you should be able to see the cooland nipple after removing the alternator.:worship: Aeros r00l.
Originally posted by Sphinxhow would i bring my low end back up?
i had driven the car both before and after the swap. there was some minor loss in the very low rpm, but only below 2000, nothing you will miss. over 3000 you could really feel it pulling alot harder than before.
this link will give you an idea of the differences, so you can see how the minor loss of torque in the very low rpm is. the power gains and improvement to the powerband are more than worth it.
makes me wonder why i havent put more of a priority on getting it done myself.2000 Mercury Grand Marquis LS HPP.
Originally posted by BMFerHow? After you remove the intake and the coolant tube (which covers the nipple,) then and only then you will see which nipple you have, unless you have x-ray vision. I think you guys just wanna see how many times you can say nipple(s).
Let me rephrase:
I can see which type of nipple I have because there is a tag hanging off it which I could read to tell me which nipple I have(part #).
That is what I meant, sorry not clear enough...My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
my $0.02
Originally posted by BigTomZthe PI intake manifold will give you 15 more horsepower on a non-PI motor. the PI cams will also add 15 more horsepower. they will also expand your powerband more into the higher rpm. the combo will hurt your low rpm torque slightly, but you'll probably still run a good half second faster in the 1/4 mile.
yeah no doubt, the low end torque loss in my friends 97 stang was negligible. you could barely tell it lost anything, and the increase in mid range power was excellent, more than i ever expected.2000 Mercury Grand Marquis LS HPP.
So let me get this straight...
I recently bought '01 GT Mustang heads for a song. They are immaculate.
If I put the PI heads/intake on my non-PI block I'll gain about 30HP? I also read that this would raise the compression, is this true?My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
Originally posted by mercenvyIf I put the PI heads/intake on my non-PI block I'll gain about 30HP? I also read that this would raise the compression, is this true?
