Mystery oil loss
    Mystery oil loss
    My brothers 90s crown vic uses alot of oil. Not leaking and not really burning it. Tried PVC and hoses. About a quart in two weeks. Any ideas?
    2000 Grand Marquis LS
    Mercury Owners Group member
    No leaks???? Pop the breather cap off the valve cover and see if a lot of smoky oil comes out from blowby like a mofo.
      Nothing that could account for the volume lost.
      What does it mean if this is the case? Bad rings?
        Yup, you can drive it like that but it fouls the plugs easy and will plug the cats after a while.
          He hasn't said anything about the plugs fouling, will have to ask him
            rear seal? running onto torque converter, but somewhat held up by the converter hole plug, so it just slowly drips out? BTW a 90-91 CV is for the 5.0/5.8 boys. This thread may be better served there depending what year he has.
              if it'snot leaking out onto the ground,replace the pcv screen.........might be clogged.........or the engine was overheated at one time and the oil control rings on the pistons are toast.........my towncar burned a qt every 400 miles like clockwork
              scott
                If it's a 4.6 car, then the problem is valve seals. '91-'95 4.6 heads had a poor design that will cause oil usage over time. The amount of usage varies, but it will be seen in the form of blue smoke out of the tailpipe when the car takes off from a stop, or idles for long periods.
                Ray
                Car: 2004 Mercury Marauder
                Engine/Tranny: 49k miles and bone stock....for now
                  It is a 4.6, It's a 90s CV, not sure of the exact year.
                    Did that
                    scott
                    exactly, that could be it.
                      Ray
                      Or this, have to let him know to check that, those simple on the 4.6's?
                        I second the valve seals. 92-95 model years have this problem. Those early (or pre-NPI) 4.6's are notorious for it. Not unlike Chevy's 305 from what I hear.
                        The valve seals are not a problem on 96+ 4.6's though, Ford used better valve seal material after that.
                        2000 Mercury Grand Marquis LS HPP.
                        http://www.cardomain.com/ride/2336322
                        Friends don't let friends drive donk.
                          Thanks I will forward him your advise
                          :worship:
                            On the difficulty scale I'd rate doing your own valve seals at a 8+. Getting the passenger side valve cover off alone is a battle.
                            Having it done at a shop will cost $600 & up, provided they want to touch it. As BigTomZ said, Ford addressed the problem in the '96-up heads. At the labor cost of the job you could pick up a newer low mileage 4.6 and replace it.
                              knowing my brother, he will drive it as is forever!
                              Thanks All
