I think I have a oil leak starting on my gm.. Its coming from a large golden screw on the oil pump on the bottom. The parts right next to the filter....I dont know what to do except replace the pump...Any help would be appreciated
HELP
Its leaking from hereLast edited by Grandmarchris; 11-27-2007, 01:30 PM.R.I.P Linsey Nelson
Originally posted by MeanVic84Chocolate Rain. Some stay dry and others feel the pain.
imports dont suck1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by Blaze86VicPut some pipe tape on the screw, that should seal it up good.http://secondhandracing.com/Home.aspx
I would use Permatex thread sealant or equivalent. The tape tears too easily.
There's also an Oil Filter Adaptor sticky here...in case the leak is dripping from there, but actually coming from somewhere else. Hairline cracks can be hard to see, and that part is under pressure so even a small crack will cause you to lose oil at an alrming rate.
Good Luck and
Good Day1993 GM LS 244K
29.5mm PI front bar, ENS greaseable bushings, 21mm rear bar, ENS bushings, endlinks. Black steelies, center caps. Stewart-Warner mechanical oil pressure guage. K&N filter
1994 Lincoln Mark VIII 144K
All airbags are now coils/struts. Junk tranny, motor donor car
Mercury Owners Group
If you don\'t like what I have to type, don\'t read it. It is only my opinion, nothing more.
