Hello I had posted a message about my 97 Marquis having a cold stall when put in gear. The problem was solved by putting in an O.E. Mass air flow sensor. The Duralast just wasn't right for the car. So always use O.E. equipment on critical components such as this. Thanks for the reponses.
Cold stalling solved
Thanks for getting back to the forum with that. It helps out a lot in the future hearing back what cured an ailment.~David~
Originally posted by mgm6397 View PostHello I had posted a message about my 97 Marquis having a cold stall when put in gear. The problem was solved by putting in an O.E. Mass air flow sensor. The Duralast just wasn't right for the car. So always use O.E. equipment on critical components such as this. Thanks for the responses.
The cheapest OEM (Motorcraft) Mass Airflow sensor I found was for $200!!!"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
how much is having your car run correctly worth to you ? I'm inherently cheap too but at some point you have to bend over and take it. Or visit a junkyard for a good used one. MAF sensors don't go bad that often.86 Lincoln Town Car (Galactica).
