FLEX spark plugs
The heat ranges are different for the Flex/Non-Flex fuel engines.
I’d recommend using the correct plug for your engine to keep things working as designed.
My Cars:
The flex engine uses one heat range colder than regular 4.6's. If you NEVER plan on running E85 (or some other gas with a higher than normal composition of ethanol) you can run the plugs speced for the regular 4.6. I run NGK TR55GP's in my flex.
Alex.
Good info as one day I may have to change plugs in the TC.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
