I may have figured it out last night. Last night, I took the belt completely off and turned on the engine. There was absolutely no sound. I spun the different accessories by hand and the only one that's making any noise is the A/C pump. From what I've been seeing online, it could just be the bearing and I think I will start with that. Also, while the engine is running you can see the slightest bit of wobbling. It may be awhile but, I will post the results of fixing the bearing if that is the issue.
Thanks for the suggestion Gadget73
