Possible fuel issue???
    2001 GM..Brothers car. He stoped and got gas today and then maybe 10 minutes later he stopped at a stop sign and when he accelerated she started to shudder and then totally died. Now she will turn over but not crank. Sometimes it sputters and acts like it wants to keep running, but dies. If that makes any sense. Any ideas are appreciated.
    2001 Grand Marquis LS
    Do you know the sound of a fuel pump priming the system?
    shot of ether in the intake may help you isolate this.
      If the fuel pump is humming, the fuel filter may need to be changed. Especially if the car got some water in the tank. That tends to stop up the fuel filter as it also works as a water catch.
        If there is little to no fuel pressure it could be the hose inside the fuel tank split open.
        I had this happen on my '91 MGM, and the issue you describe sounds like the same symptoms I had.
        It could be other things such as the fuel pump or fuel pump relay gone bad. If you can't do a fuel pressure test, do what jaywish said to narrow the issue down.
        Bad relay or clogged fuel filter like Sly said would be the easiest things to fix. Bad pump or even the split hose would mean pulling the fuel pump assembly from the tank.
        Vic
          Take the filter off and dump it into a can. If you see chunks and/or water, you have your answer. That was just about the first diagnostic process I learned when I was messing with boats for a living.
          If the filter doesn't have a lot of crap in it, aim the hose that is on the rear side of the filter into a container and have someone turn the key on. You should get a nice shot of fuel out of that line if things are basically working OK. If no pump action, either the pump, it's power circuit, or the in-tank hose have failed.
            Jay we can hear the fuel pump when we turn the key on..which is weird because I have an 01 as well but can't hear it. I think the previous owners replaced this pump so it's aftermarket.
              Thanks guys I will try all those. You can hear the pump when you turn the key on....so gonna start with the filter.
                Ok,
                Next step I would try is a nice shot of ether in the intake just after the air filter in the top of the filter box. I say just after the filter because I think you have a sensor inline after the filter that needs to be working for the car to run.
                If it runs on the ether then it is a fuel problem, if it does not run then it is ignition.
                  It'll start with the mass air sensor out of the line, but it won't run well and it may not stay running. If the MAF is bad, it won't run either but usually it will start and die. Quick and dirty test for that is to unplug it and see if it runs. With no MAF plugged in, it will run on some sort of fail-safe values and start. Might not run well, but it will run.
                  If its not fuel related, a crusty connection to the crank trigger or a bad crank trigger is the usual reason for a lack of ignition.
                    You have plenty of good advice.
                    Keep us "posted".
                      Did he fuel up and a real gas station, or one of those hole in the wall with fuel of unknown quality and contaminents? I'd be draining the fuel, changing the filter (if it had water in it, it won't pass fuel very well), dump a container of isopropyl based water remover in the empty tank, and getting a batch of known good fuel in her.
                      Alex.
                        Going to change the fuel filter this weekend. Haven't been able to get to it yet. Thanks and I'll keep you updated.
                          Update.....we changed the fuel filter, and it starts now, but dies rather quickly. Won't take any throttle at all. Unplugged the MAF and the same thing. Seemed to actually start better with MAF unplugged but ran for maybe 5 seconds if that...and very rough. Going to try to clean the MAF. Is it worth cleaning the IAC or just buy a new one?
                            always worth cleaning the IAC.
                              engine off, initial key on fuel pressure psi?
                              Dump the fuel, replace the fuel filter again and fresh fuel from a real gas station. No randomn POS station just becuase it has the lowest price.
                              Alex.
