The basic orange frams are real econo filters that cost a little more than a no-name econo. The only nice thing about them is the grippy paint.
What brand and weight oil are you using and what mileage interval?
Originally posted by FordMan77 View PostNONE of my cars or any other things with engines ever get a Fram filter. Watched a buddies 5.0 drop pressure to 0 when his filter failed for some reason. Shut it down, changed the filter out and whallah- oil pressure restored. Not sure wtf happened, but it was enough for me.
On topic, 5.0 or 4.6, I always use 10w-30 @ ~3000k miles.. but most of the cars I've owned have been higher mileage to begin with anyway.
The orange econo Fram filters are garbage. They're made of cardboard and junk craftsmanship. Take a look at this thread and see the difference between the econo Fram & a wix:
http://forums.focaljet.com/showthrea...s-other-filter.
I run Fram air filters when Motorcrafts aren't around but I'll never run any of their oil filters.1985 LTD Crown Victoria - SOLD
I do like the fram premium gold colored filters. They are called Ultra. I have cut open a used one and it still seemed in perfect condition. As you know I agree about the orange ones.
http://www.fram.com/oil-filters/fram...-oil-filter/#2Last edited by jaywish; 09-16-2015, 07:30 AM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostI do like the fram premium gold colored filters. They are called Ultra. I have cut open a used one and it still seemed in perfect condition. As you know I agree about the orange ones.
http://www.fram.com/oil-filters/fram...-oil-filter/#22008 Ford CVPI ex Boone County, MO Sheriff
Originally posted by slack View PostInteresting. I had a similar issue with a Fram filter. Back when I had my '91 Grand Marquis, I did an oil change with 10w-30 and a Fram filter. Less than a week after the oil change, the oil light came on. I parked it immediately. Swapped the filter for a (I think?) Mobile filter. Oil light didn't come back on again for the duration I owned the car. That was last time I bought a Fram filter. I had used them for years before this without ever having a problem but one close call was enough for me to not chance it again.
Originally posted by Primalzer View PostApparently the high end Fram's aren't bad filters...but for just about the cost of an orange Fram filter I can get a Motorcraft filter, which are great filters. When you consider their price, they are almost unbeatable.
When all else fails, its a safe bet to use the OEM filter. The manufacturer doesn't want warranty work because their own filters are shitty.86 Lincoln Town Car (Galactica).
Originally posted by mercurygm88 View PostUnless you go for the premium brands and lines of filters (K&N, Bosch, Fram High Mileage, Royal purple) they're all within 50 cents of one another at auto parts stores around here, I can get a Motorcraft filter for $3.99 thats 30 cents more than store brand and 20 cents less than the shitty Fram. I can get the Motorcraft filter for $3.19 or $3.50 at Walmart, and the Motorcraft oil is cheaper there too.2008 Ford CVPI ex Boone County, MO Sheriff
Originally posted by sly View PostInteresting. The 2000 CV specifically says 5W30. On a good and tight engine, I have no doubts that 5W20 would be fine, though.
Originally posted by mercurygm88 View PostThe '95 said 5w-30 for all climates in the manual but there is a printout in there with a TSB from Ford in 2001 saying to use 5w-20 in all 4.6's, my grandparents must have printed it out and put it in there when they had the car as a reminder. The '01 Town Car specifically calls for 5w-20 in the owners manual.
After trying "other" crap, my '98 definitely preferred Motorcraft synthetic blend 5w-30 and Motorcraft filters. It got to the point where the local dealer was sending us so many coupons that it was cheaper to have them do it than do it myself. I now take the '90 there and am using the same oil. They recommend 5000 miles and that's what I stick with. It usually starts looking kinda shitty by then.
Originally posted by knucklehead0202 View PostAfter trying "other" crap, my '98 definitely preferred Motorcraft synthetic blend 5w-30 and Motorcraft filters. It got to the point where the local dealer was sending us so many coupons that it was cheaper to have them do it than do it myself. I now take the '90 there and am using the same oil. They recommend 5000 miles and that's what I stick with. It usually starts looking kinda shitty by then.
They say that's how you can tell the oil is doing it's job. That or tons of sludge hiding out in your engine lol. Oil starts out the color it is in the bottle but by the time we get ours changed it's a dark tan, but not black.1985 LTD Crown Victoria - SOLD
