Buckling, misfiring, hesitation
    No tapping but missing under acceleration
    2000 Grand Marquis LS
    Mercury Owners Group member
      Check engine light now on
        then you have a code you can pull to see which one.
          Well it hurt to drive it like this
            Po307. Cylinder 7
              AFAIK, you risk messing up your cats if you drive with a misfire.
                Unplug that injector?
                  Swap the cop with #6. if the misfire moves... the cop is the problem. might check the plug too while you're in there. If the plug is ok and the ceramic portion doesn't spin (should be tight), just put it back, otherwise clean/replace as needed. If after all of that, the misfire stays on #7, injector, or compression/valves.
                    It's a very inconsistent miss. Comes and goes
                      If I unplug the injector should be ok to drive temp as no fuel will go to that cylinder to be dumped in the cats
                        If you unplug that injector... it probably won't idle very well at all if it does. It'll drive even worse.
                          Ok. Have to go to my doc appt tomorrow and no spare vehicle. Sigh
                            Just drive it and stop by the parts store on your way home for the part.
                              Also, when my coil went out, I didn't get a misfire code. When a spark plug went out, I did get a misfire code. It seriously could just be the f'n plug.
                                Can't buy it till Friday. Hospital is 20 miles
