Rusty engine after putting off manifold replacement
    Ok, so my 97 TC's intake manifold finally cracked about five months ago. I was still driving it because it's my only car and I'm relatively poor. I had it replaced today, and the block was full of brown water/antifreeze mix. What's the best thing to use to do a pretty decent flush and get the cooling system as clean as possible?
    "No other man-made device since the shields and lances of the ancient knights fulfills a man's ego like an automobile." -Sir William
    2011 Lincoln Town Car Signature Limited- Black on black, ADTR sway bars, 19" Mustang GT rims, Heinous rear control arms, dual exhaust with Flowmaster 10 series mufflers. MHS Stage 2 heads/cams, 80mm MAF, 75mm BBK throttle body, Accufab plenum, Stainless Works long tube headers, Ford Racing 24# injectors. ADTR T56 swap with Hurst shifter. 264HP/298TQ at the rear wheels.
    just use the coolant flush stuff and follow the directions. You may have to do it more than once. You may also have to take the lower hose OFF to clean it out as I'm sure there will be loads of sludge in that one. You may also have to get the hose and run it through the radiator to really flush it out. Follow that with one gallon of distilled water just to rinse the tap water out.
