My steering wheel got randomly stiff when turning?
    Hello, so I was pulling out of a parallel parking spot yesterday. I turned the wheel all the way to the left and then pulled out and went to turn the wheel back and then the steering wheel got REALLY stiff (hard to turn back) and that almost made me go head on into a truck driving the opposite direction.
    I was thankfully able to forcefully turn the wheel back in time. If feels like my power steering cut out... I noticed that there was no noise when this happened.
    Could this been because I was turning the steering wheel all the way left then back to the right too fast?
    ____________________________________________
    2001 Mercury Grand Marquis GS 62K miles
    Possible! I would still check your power steering fluid (level) and all front end parts for damage/wear.
      Might also check the belt. and tensioner. If the belt is old or loose on tension when you turned back fast maybe it slipped just enough that the PS assist cut out.
        There's a good thought!!
          I changed the belt on my 2000 MGM some years ago because of all the cracking on the ribs, though I kept the old one for emergencies. I never gave any thought to the tensioner, and the bearing on it ended up disintegrating. I lost power steering on an exit ramp intermittently. Luckily, what was left of the belt still managed to hang on, and I was able to get to a convenient parking lot. The tensioner was expensive, but at least I got a replacement belt under warranty. Moral of the story: don't neglect your tensioner.
            Call ford and ask if your car is elligible for any steering shaft recalls or TSB. There is more than one and they can cause bind.
              X2 on this. Stop driving the car until it is replaced ! Especially if you live in the rust belt areas of the US.
                +1 steering shaft.
                  Mine was JUST doing this, except the wheel wasn't just stiff, it was LOCKED to the left. Had to to crank the wheel to the left as hard as I possibly could and move the wheel back to the right quickly. At first it would just do it at slow speeds making sharp lefts in a parking lot or when making a u-turn. Then it started when I was just making normal turns or even going around a curve.
                  -4 ball joints and an alignment later and it handles great!
