I have a 1994 MGM, and it runs and drives great, no drivability problems EXCEPT for one thing. Consider the following scenario
1. Engine is completely up to operating temp (to prevent damage)
2. Engine is floored from any gear other than first
3. Transmission drops a gear and engine revs high
4. Engine shifts after reaching maximum RPM (because floored)
5. Let off the gas
6. Engine settles down fine
7. Apply a light amount of gas
8. An extreme misfire will occur SOMETIMES
So what I'm saying, is after flooring it and letting off the gas, trying to apply a small amount of gas after the pedal-to-the-metal-action causes a pretty extreme misfire, but I'm not sure in which cylinder, the car will jerk and stutter violently, and if I let off the gas again and let it calm down, the misfire will go away. The misfire does not occur under any other driving conditions. The misfire doesn't even always occur after flooring it. Just sometimes.
Spark plugs and wires done 2 years ago
Have not done coil packs
Oil changes every 3 months (odometer is broken)
Transmission has fresh fluid from a flush about 8 months ago but it was transmission fluid from a shop, not Mercon V. No transmission issues so far.
New serpentine belt
Muffler removed, both catalytic converters inoperable (blown out).
Check engine light does not occur when misfire does, and running diagnostics through the under hood diagnostics port comes up with a clean bill of health.
What's going on here?
5. Let off the gas
New serpentine belt
