I drive a 2004 mercury grand Marquis gs. What my goal is is to get the reader end to go for one wheel drive to both and I want a 5 speed automatic transmission. What I need to know is where to find said transmission and what would be necessary to make it all run smoothly. It's all stock no air springs
project in the planning stages need help!
You will need an external transmission controller and a tune to disable PCM control of the transmission as it can't control it. The 5R55W would probably be your best bet, but which version you'll need is unknown. For usability with the stock shifter, you'd never be able to manual shift down to 1st. If changing to a custom console shifter, sky's the limit. You could even use the select-shift (manual mode) with the 5r55s. I have no clue which version bolts up to a 4.6 though.
Personally I'd love to have the 6R80 from the mustang... but those are still even harder to come by.
A traction lock is the magic piece to get two wheel peel. Pretty sure the late models were still using an 8.8" rear.86 Lincoln Town Car (Galactica).
yeah... but when did they switch to 31 spline axles?
03 Mercury Marauder- 63k
Doh! So 28 spline carrier or upgrade the axles and get a 31 spline setup.
I wouldn't wish a 6R80 on anyone. I had one in my F-150 and it was awful. Maybe the transmission wasn't the problem and the programming was, but it was one of the major reasons that I got rid of my 2010 F-150. Horrible driving experience.Nick
Originally posted by LithiumCobalt View PostI wouldn't wish a 6R80 on anyone. I had one in my F-150 and it was awful. Maybe the transmission wasn't the problem and the programming was, but it was one of the major reasons that I got rid of my 2010 F-150. Horrible driving experience.
EDIT: I should also note that the shifts in my truck are noticeably more snappy in Manual mode than D, especially the 1-2 shift. I'm considering a mild tune on my truck at some point, to have it shift the same way in both modes.Last edited by RyPow; 09-17-2014, 11:54 AM.RyPow
1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
2007 Lincoln Town Car Signature Limited, 102k, daily driver
2006 Mercury Grand Marquis LS, 115k, winter beats
1977 Lincoln Continental Town Car, 42k
2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
2015 Toyota RAV4 XLE AWD (better half's)
Originally posted by RyPow View PostIt was the programming. I test-drove a brand new 2010 F-150 5.4L and hated the shifting behavior. Fast-forward to a 2012 with the 5.0L....totally different story. Much more responsive with downshifts, and nifty TC lockup behavior. I went from despising the 2010 to factory-ordering my 2012.
EDIT: I should also note that the shifts in my truck are noticeably more snappy in Manual mode than D, especially the 1-2 shift. I'm considering a mild tune on my truck at some point, to have it shift the same way in both modes.Nick
Originally posted by LithiumCobalt View PostI figured it was a programming problem. Everytime that I would roll into the dealer they would claim there's a new calibration. They supposedly reprogrammed it 3-4 times. Could never tell any difference. The transmission quirkiness, lack of kickdown response and a driveshaft bump on stop/start was enough for me to trade off a 45k truck. The drivetrain was about as unrefined as any vehicle I've had to date.RyPow
the 2-segment drive shafts come with the wiggle. It's always been an issue. Single segment shafts eliminate that issue, but reduce your ability to crawl over stuff if needed (not an issue for a tow rig usually). But getting a single segment shaft for a crew cab long bed would be a tall order as it would be one f'n long shaft.
On the 2013 shifting seems fine. Problem with this one is a buzzing/moaning through 2-4 gear. Very intermittent. There is a tsm now for it to replace the valve body separator plate. Others have it also after driving and shifting into park. One such person made a video showing it is the cooler line vibrating like mad. I at least want to video it before taking it in. I don't think they will do the service without evidence. Maybe a set of factors getting a resonant frequency? Has to be warm but not hot. Won't happen after about 10 min of driving. Only with light normal acceleration and goes away if pushed more.sigpic
89 LTC 429>557 Cobrajet stroker
13 F-150 XLT 6.2 l
"If I could separate what's real from what I've been dreaming I could live to fight another day"
