Swapping parts
    Swapping parts
    Hi I found a 92MGM for sale in Wisconsin for cheap. I was thinking of swapping out parts but can you swap out the door of a car with a keypad and have it work? My car does not have a keypad. Thanks -Trevor
    Sent from my Torque using Tapatalk
    The module for the keypad is actually in the driver door. That's where the five-digit code for entry is.
    I don't know how to make that keyless entry system work. You'll probably have to run some type of relay to power the module. Then it has to connect to the other doors as well. But you should be able to do that fro mthe driver's door already if it has power locks.
    Other electrical-savvy mangs should chime in.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      I think it runs off the power lock/windows that's hot at all times. I don't see why it wouldn't work. Check the harnesses that come into the door on both vehicles and see if they match. If so... I would bet just swapping the door (or the guts) would work.
        Ck EVTM to see if any associated wiring goes back into car from door.
        65 Galaxie 500, 67 Mustang, 57 F350, 4- 77-79 LTD II, 68 LTD XL, 80 C V, 82 C V, 92 C V police, 74 P40, 92 G M
        10 yrs in Ford dealers, ASE Master Cert expired in '92, Forgot more than I remember, 15 yrs in speed shops,
        '80 Kaw KZ 1000 ST Turbo, converted to chain drive
