Cold engine misfire
    Cold engine misfire
    1993 civilian CV. 130K 2-owner miles. The car has very recently started running like absolute crap in the mornings. Weather has been hot and dry. Car seems to be running on 7 if not 6 cylinders, and will briefly smooth out for a second or two, then back to misfiring. As the car warms up, it gets better. I only live a mile from work, and it is improving by then. The rest of the day, it is very smooth, with just an occasional misfire hiccup.
    I replaced plugs about 3 or 4 years ago at probably about 100K miles - possibly for the first time. The car burns a bit of oil through the valve seals, but not bad. Plug wires say "motorcraft" and could very well be original. Also, I have not replaced coils and do not believe prior owner did either. I hooked my inductive timing light up to various wires, and the light was not flashing regularly. However, the way the wires run, I may have been getting bleed from another wire. I have not pulled wires from plugs to look down into the plug wells, and do not notice any coolant leaks.
    Does not seem to be engine-temp sensitive, but more like ambient underhood temp sensitive. Also, it feels very much like an electrical misfire and not a cold-run fuel problem. My guess is I should try plug wires first, coil packs second. Any words of wisdom from Panther experts?
    J. P. Cavanaugh
    1993 Crown Victoria LX
    I'd go for plugs and wires. If it burns oil, the plugs are probably crapped up. If the wires are original, they're also likely due for replacement. Wires tend to get leaky and cause craptastic running when damp, which I'd expect in the morning more than other times.
      yeah... since the plugs have been replaced... you might need to replace the wires now.
        Problem fixed. New plugs, wires and coil packs. Runs like a new car. The wires were probably 20 years old. I thought about doing wires first and sticking with old coils, but figured that those things probably have a design life of less than 20 years, might as well replace them while I was in there. I went with the Delphi units from Rock Auto. Thanks everyone for the suggestions.
          hang onto the old coils just in case the new ones crap out.
            I did indeed hold onto them just for insurance. I figured from the outset that there was a chance that they would be good, but I just replaced them because they are 20 years old. I just put them on the shelf with the other forgotten parts I have kept as insurance over the years.
