strange idle
    strange idle
    when im in park or neutral, the idle surges every couple of seconds. not a high rpm surge, maybe 200-300 rpm surge from idle. its been doin this for a while but i really notice it now with the loud exhaust. any ideas on what it could be? i checked it with a scan tool and no codes were thrown from it. ill get a video of it once i get the time, maybe when im on my lunch break or something.
    2010 Toyota Camry "Traveller II "
    54,xxx miles. New daily driver
    2001 Lincoln Town Car Signature "Leroy"
    rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
    114k miles. Sold to my coworker.
    1998 Toyota Camry "Traveller"
    Dead and sold.
    Throttle body clean out or IAC??
      Possibly a misfire?
        I replaced the iac and cleaned out the throttle body last year
        Dead and sold.
          Originally posted by Ryan12689 View Post
          Possibly a misfire?
          That woulda thrown a code if it was a miss. I thought that's what it was at 1st but I checked it and only code it had was for the fuel level sensor which has been bad for a few months, and the problem started before that
          Dead and sold.
            loud exhuast?....hmmmm id try looking at at the exhuast system, apparently the manifold bolt like to let go or break,as a well as the seal underneath just after the cats. a clean iac dont mean that it will work forever. i had to replace mine eventually becuase it would idle stupid at stop lights.
              Would get an OEM IAC. Don't know about anyone else but have seen too many issues with aftermarket ones - even new ones!!
                i went with a motorcraft IAC, i didnt wanna go with any other brand cuz i trust motorcraft over all of em
                Dead and sold.
                  i replaced the iac, i cleaned the tb. i think i might have a manifold leak
                  Dead and sold.
                    it'll also do that if the MAF is dead/disconnected (found that out on my Mark one day - reconnected the MAF, all was well)
                      Not all misfires show a code I just dealt with a misfire on cylinder three that didnt throw a code, my buddies genesis found it though
                        i know its connected sly, but how would i go about tellin if its dead or not?
                        Dead and sold.
                          ill have to check into it, thanks!
                          Dead and sold.
                            pulled the plugs...all SHOT! and have oil leakin in cylinder 4...im hoping valve seals, gonna kill myself if its the rings
                            Dead and sold.
                              to test the maf, unplug it. if nothing changes... it's likely the problem. But it looks like you found the problem. Bad plugs.
