Got a 2000 grand marquis with 27k miles what oil should I put in
What type of oil should I use
Probably calls for 5W30 but the Owner's Manual will verify that.
5W-20
03 Mercury Marauder- 63k
I believe the 5W20 began in 2001 but do verify that! Bobby
it will call for 5w30. Ford started putting 5w20 in at a later date, but issued a TSB recommending running 5w20 in older 4.6 as well. Really, its your choice. My car uses very little oil, but it seems to use alittle more on 5w20 than it does on 5w30, I noticed no other differences. I run whichever weight is available, and if they have both I run 5w30.-Steve
If everything else you own uses 5w30, no reason to not use it in your 4.6. I use Dexron in my fords power steering becuase I don't want to be bothered with having a lone bottle of Type F kicking around when everything else I have uses Dexron and I've got plenty of bottles of dexron already becuase of it.
Alex.
