My 01 towncar starts every morning, but when I stop and try to start it within 0-10 minutes of being off it cranks but doesn't start. After waiting 10 mins. the car starts and will run until I turn it off. It doesn't seem to matter if it runs for 2 minutes or 2 hours, It won't start back up for that 10 minutes.
When it's running, the idle is fine and there's no loss of power at full throttle...It drives as it always has.
I tried to boost it which failed, then I checked and found that there's fuel pressure at the schrader valve on the fuel rail, and there's spark (I checked on a couple of the plugs). I cleaned the CKP sensor connector as suggested on another thread but it still has the problem. I also swapped the relays around which didn't change anything.
Any suggestions?
Any suggestions?
