Hi guys I just got a 94' marquis 4.6 with about 117k on it. It has the same problem everyone else on this forum has it lacks power. I checked the Maf, TPS sensors and they are fine. I also checked vacuum lines and they are also fine. You cannot floor this car the engine spits and sputters after 3/4 throttle. I am getting code 172 HO2 sensor detects engine lean left bank, 176 Ho2 sensor detects engine lean right bank. What's next?
Just bought a 94' Marquis LS
Welcome to GMN! 117K is not too much but a tune-up might be in order...New plugs, wires, PCV valve, etc. If you want the best parts, go with Motorcraft. If you want to save some cash, try an after-market brand.
If you experience any other issues, post away'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
replaced fuel fliter didnt help, also has a tough time warming up sounds like engine is skipping till it's compleatly warm. plugs were whiteish head gasket maybe? I wan't to find out soon because it pains me to drive this car with it having no balls, it's a sweet car.
White plugs doesn't necessarily mean anythings wrong...but they're probably worn.
That's definitely where I'd start. New plugs and wires.
But if its throwing lean codes... it may be the MAF or EGR valve. How did you check the MAF? I've heard you can clean them with an electric parts cleaner I think the CFC brand makes one called "Lectra-Motive." Take the MAF out and spray it a few off.1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
1985 VW Vanagon 70k~
Originally posted by DriverSideImpact98 View PostWhite plugs doesn't necessarily mean anythings wrong...but they're probably worn.
CRC makes a MAF cleaner and a non residue electrical contact cleaner.
Pull the PCM fuse OR the battery ground.
Remove the airbox
Spray the MAF wires without touching them with the spray straw.
Let it air dry for 20 minutes.
Replace airbox
Replace the PCM fuse.
Ah..Crap.. OBD I ..
Does OBD I have a KAM code file ? Will his PCM keep treating his clean MAF like a dirty one like OBD II cars will ?
egr passages in the intake may be clogged up also
Originally posted by AKA_Rizzo View PostI mean to back you up not prove you wrong.
Remove the airbox
Replace airbox
Ah..Crap.. OBD I ..
Does OBD I have a KAM code file ? Will his PCM keep treating his clean MAF like a dirty one like OBD II cars will ?1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
you say its not getting up to operating temp or slow to... have you replaced the T/stat?2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Just curious if you solved this problem. My car is doing the exact same things (slow to warm up, bucks over 1/2 throttle, poor acceleration) but seems fine when warm. I replaced fuel filter, air filter, plugs, and PCV and there was no change. I also had very white looking plugs. I get different codes however, the main one being 332 (EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE). If you fixed it please let me know. My next steps are replace EGR valve and clean passages, but I'm waiting for some warmer weather lol
Definatley look at your MAF. I fought my car all summer with the bucking, no power when cold. I had the MAF replaced and it was like driving a brand new car.1998 Crown Victoria P71: Former National Institiute of Health vehicle
1974 VW Beetle
