'95 TC?
    '95 TC?
    Looking at a '95 Town Car. What issues do I need to look for? I know there are some issues with the intakes and valve seals, but what years? 125k on it.
    intakes on a 95 are not a problem.......95 is the end of the valve seal problems.......my 95 thunderbird 4.6 would use a quart of oil every 1000 miles or so......the turd had at least 150k on it......the odometer was always broken
      Thanks Scott. My search for a whale might be over, then. This TC has a crazy color interior, though. Somewhere between porno red and burgundy.
        Hi Torquelover
        Blocked EGR channels (check engine lights after a few minutes on the road), oil leak from the filter adapter gasket, windows not working (but motor running), transmission shudder and all the usual 125,000 mile wear and tear shit.
        Regards
        Dereck
        President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
          Also possible air suspension issues, but they're easy enough to fix, either with air springs or coil springs if you want to go that route. If the back doesn't sit on the ground overnight, its fine.
            Thanks for the help!
              Is the TC's exterior red also?
              '79 Continental Town Car
              '90 Crown Victoria LTD
              '94 Crown Victoria
                If it's still there, I'm going to look at it this weekend. I posted some pics here:
                http://www.supermotors.net/registry/media/705168
                  Also, the blend door motor for the climate control shits the bed, so you might have to change that. It just goes, click, click,..
                    Do the valve seals ASAP. Dont fuck around. Clogged EGR passways, clogged cats, blue smoke, fouled plugs, and contaminated o2 sensors are in your future.
                    Look for a 96 in my opinion. Just gotta change the manifold.
                    95 has all alumi. mani.
                      the '95 TC looks nice!!
                      Poor Subaru though.....
                      '94 Crown Victoria
                        What's special about the '96 model year?
                          Hi 1987cp
                          Nothing!
                          It has a few more toys than a 97 and that's about it.
                          It was the first year for the plastic intake which in my opinion makes it worse than a 95
                          Regards
                          Dereck
                            I do miss it. It was a darn good car.
                            I really would like to find a black on black handling-package equipped TC, but every one I see is thrashed pretty badly. My funds won't be here for a few weeks yet, so I have not gone out to see the '95. Not many people are buying big V8 cars right now, so I hope it's there when the time comes.
