I feel honored having the first "real" question posted up in here :banana:
565 Canister purge solenoid (CANP)
332 EGR valve not opening
337 Electronic pressure transducer (EPT)/differential pressure feedback exhaust (DPFE) sensor/electronic vacuum regulator (EVR)
634 Neutral drive switch (NDS) circuit failure
Got those error codes from the KOEO test in my '94 GM, the 565 was the only hard fault, all others were memory codes.
I posted this on CVN and was told to clean out the EGR valve first, reset the computer, then see what happens.
I'll probably do that soon, but if anyone has any more advice, let me know
