i am new to this site. i got a 1992 grand marquis it has 177000 miles on it. it is smoking when you first go. white smoke..should i replaced gaskets. or something else. radiator fluid is going some where? so is the oil. i can get a 1996 motor that has 40000miles on it cheap. would it bolt up. i have looked and looked for two days.. even bought book at the auto parts stores. and they dont say anything about it any help would be great... i dont have a problem with doing some work
a lot of questions
has the engine been overheated? if so toss it..........ok there is a slight problem with the 92's........you need to look at the production date on the door sticker......if your car was built before 2/92 you cannot use a 1996 engine........you will need to find a 4.6 from a 92 vic or marquis built before 2/92 or a 91 towncar
yep it's a bastard block 4.6 (4.6 engine but it has the same trans bellhousing as a 5.0) like i said they were produced until 2/92.
Welcome to GMN!
Your oil is going out the tailpipe (via the white smoke)
The coolant loss could be a multitude of things. Try pressure testing it (with a cooling system pressure tester) or take it to a shop.1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
More than likely the intake manifold is cracked if you're losing coolant. If you haven't driven it much since that happened, you may be all right, otherwise it's new engine time.
Originally posted by Nathan in MN View PostMore than likely the intake manifold is cracked if you're losing coolant. If you haven't driven it much since that happened, you may be all right, otherwise it's new engine time.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Oh. Oops.
92's have aluminum intakes
pull the spark plugs, look for green on the spark plugs......sure sign of a leaking head gasket
