My '94 Grand Marquis has the infamous leaky valve stem oil seals. I'm perfectly fine about the way it is, because i always check the oil and the rest of the underhood fluids along with tire psi every fill-up. I'm just curious if anyone with the leaky valve stem seals has used valvoline maxlife oil or castrol high mileage... with any type of success in lessening the amount of oil consumption?
Valve Stem Seals
Not shure what year fordd changed the intake ports from high swirl to tumble ports 94 might have been the last yer for swirl. The high swirl ports chevy did it to caused some of the worst cylinder and rig wear I have ever seen. I would have the compression checked to conferm if its seals or rings.Scars are tatoos of the fearless
Ford "corrected" the valve seal issue in '96.
As for MaxLife, etc....I don't know of anyone that has tried it. At least no one that has posted results of said use. You could give it a shot and let everyone know how it works for you.
RayCar: 2004 Mercury Marauder
Engine/Tranny: 49k miles and bone stock....for now
Originally posted by 93 Marquis View PostFord "corrected" the valve seal issue in '96.
RayScars are tatoos of the fearless
allright mang i'll do the next oil change with maxlife keep everyone posted.
Just curious which monroe front shocks are good for keeping the grandpa-style ride on the marquis? how quickly can the average shop change the front shocks? they seem pretty accessible from the top and bottom.
