I think that my waterpump may be failing. Is there a special tool to remove the serpentine belt? I have a long breaker bar but that does not quite reach. Also is the waterpump a pain to change on a 92 Grand Marquis?
Special Tool For Removing Serpentine Belt
Hey I think you can use a 1/2" breaker bar to remove the belt, I used one to remove mine. The water pump has a "weep hole". If you see coolant "weeping" from this hole, then you need to replace your pump.....sorry.
[img] waterpump.jpg [/img]Apparently I tried to send you a picture of it, but I am too computer illiterate to understand how to attach stuff.1993 GM LS 244K
29.5mm PI front bar, ENS greaseable bushings, 21mm rear bar, ENS bushings, endlinks. Black steelies, center caps. Stewart-Warner mechanical oil pressure guage. K&N filter
1994 Lincoln Mark VIII 144K
All airbags are now coils/struts. Junk tranny, motor donor car
Mercury Owners Group
If you don\'t like what I have to type, don\'t read it. It is only my opinion, nothing more.
If you need to host the pic, email the pic to me...
hot_rod_linkin420@yahoo.com
ill take care of it when I get home
Also, a good serp belt tool is this flat breaker bar like object that gets into a confined space. I got one, they are awesome!1983 Grand Marquis 2Dr Sedan "Mercules"
