my car won't shift into gear .. i've checked the shift tube and its fine .. anything else to check ?
94 marquis won't shift
linkages under the car? remove cover from steering column and make sure nothing has come loose and is inhibiting the shifter from moving. I think I recall someone mentioning a screw or something that worked loose but I don't remember it was a while ago on a different board.93 Town Car Cartier 150k mi
01 CVPI, (Count Blackula)155k mi
I was just able to jack the car up on all 4 and get under it while running and maunualy shift it into gear .. took it off jacks while in gear and drove around and seemed to be fine just unable to shift from the colum
I have a steep drive way has anyone heard of the cable breaking that goes from shift tube to trans ?
Could this be a good reasson to fabricate a floor shifter ? humm ....
Yeah the cables can break. Hey its 12 years old, stuff happens. teamfordparts.com should be able to get you the replacement, and so can the local dealership if yours isn't staffed by idiots.86 Lincoln Town Car (Galactica).
yea i replaced a split cable on a ford truck recently
try teamfordparts.com for the cable mang
