I plan on replacing the front control arm bushings on my '89 CV LX. Does anyone have a set of the locking nuts needed for the upper control arms? As I seem to have read, the originals are not re-usable.
locking nuts for upper control arms
I have a few, but to be honest you’d probably do just as well ordering them from where I did: https://www.grainger.com/product/FAB...ock-Nut-29DU72-Phil
I torqued them to spec and one actually came loose...so I'd use the locking nuts AND lock tite...-Phil
I ended up using some jam nuts on a couple of the pinch nuts I got because they wouldn't hold.
Would make sense for it to be metric, all of the other body and suspension hardware is. Wasn't something I considered at the time, the sticky on here I think specifies 5/8 fine.
McMaster-Carr is my usual go-to for hardware. Also just seems to be better quality than the stuff I get from Grainger at work.
I think I'm using 5/8 hardware on mine, McMaster sourced, and it hasn't come loose in the almost 15 years its been on there. When I re-used the original nuts they came loose almost immediately.86 Lincoln Town Car (Galactica).
