Hello i am rebuilding a 68 Rivera. My question is does anyone know where i can locate a 351w? The engine in it now is toasted. Thanks for any information
1968 Buick Rivera
I would try facebook marketplace or craigslist. If you aren't looking for a roller 351w then they are all over the place-Phil
Why are you putting a 351W in a 68 Buick?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
82-97 Trucks and Vans are pretty typical donors. A lot of the 3/4 ton are equipped with the Windsor’s.
You’ll need a trans too to put this in a Buick.1990 Country Squire - under restoration
Wouldn't it be easier/cheaper to find another 430 to slip in than to redesign the entire drivetrain for the Riv?These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
wait a minute. years ago there was someone who came here with a buick that someone swapped in a 351w. maybe the seller of the car told that person about gmn.Last edited by Lincolnmania; 01-04-2021, 08:08 PM.
It is definitely easier to go back with stock engine. No adapters/fabrication needed. You could probably do an LS swap in that as there's probably aftermarket adapters and mounts ready and waiting for purchase. If the old engine isn't completely wrecked, a rebuild might actually be the cheapest option unless you find a known good, used engine. Some general wisdom is that no used engine is good until you tear it down and make sure it is actually good. And while you're in there, replace all gaskets so it won't leak. Obviously, stock for stock is a sure recipe for proper repair, but newer power plant may be a good option if you or someone you know is willing to fabricate a few things to make it fit.
