Hey guys still having issues with my Town Car only thing I haven't checked is the ECM. Need another Mark VII to pin down this issue before I create even more issues with a MAF conversion. Years that will work should be 1990-1992. Thanks.
Mark VII ECM 1991-ish
Whatcha lookin to pay for one? They're getting kinda scarce ya know...The ones who accomplish true greatness, are the foolish who keep pressing onward.
Still need one? I'm not sure exactly which I have but it's a MK7 ecm with the tweecer port.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
