Im looking for a steering column for a 90. something in my shifter broke feels like a spring but it just alot less work to change the column than to rebuild the shifter.
1990 steering column
Any 90-91 column will at least need bushings unless they've been replaced recently.
If it still shifts but is a bit sloppy, those bushings may be all you need and they're maybe $10.
If it doesn't shift at all then you need a shift tube. While replacing the shift tube can be a little tedious, I would rather replace it than replace the whole steering column. Of course it's your call, replacing the whole column might be less time consuming.Vic
