I have a 1996 Gm and I'm looking for the Clutch Fan would need to be in driving distance of Toronto
Clutch Fan for a 1996 Gm
the fan blades or the thermal clutch... both are available at parts stores... at least stateside and I would use new parts if at all possible as old parts probably won't be any better than what you're replacing. You also need a massive adjustable wrench to get it off (or the fan clutch tool - which is just a thin open end wrench with a breaker/ratchet slot). I find the big wrench and a small counter wrench on one of the pulley bolts to be the easiest way.
