Need both front fenders for my 2001. Must have little to no rust and if you have my color( champaign gold I think its called) I will pay more. I'm located in kitchener Ontario and will drive a bit for them.
2001 GM front fenders wanted
I could actually use a pair for mine, but I'm willing to live with the rust for now. I've seen that you can get new ones with just primer, and here's an example:
If you go with used ones, you might want to consider spraying a crapload of RustCheck (both the red liquid Rust Inhibitor and the thick Coat and Protect) through the fender liner bolt holes to prevent the wheel well lip seam from rusting from the inside out like mine did. Spraying mine with RustCheck while replacing my upper control arm bushings seems to have prevented the rust from progressing, and I can live with it for awhile.
