LTB Coil harness
    LTB Coil harness
    I'm looking for the harness with connector for an '84 GM. It plugs into the coil.
    Hope the pic helps.
    '93 T-bird
    '03 Silverado ECSB
    Missed:
    '88 Mark VII
    '86 CV
    Bump.
    I hope this pic is better.
    '93 T-bird
    '03 Silverado ECSB
    Missed:
    '88 Mark VII
    '86 CV
      Are there any junkyards near you? Many, many Fords used that coil and therefore the same connector, I doubt it would cost more than a dollar or two if they even charged you for it.
      I know the second gen Taurus, which is very plentiful in yards due to its fantastic transmission, has what you want.
      | Junkyards
        RockAuto has that plug. Solder a brand new one on instead of using another one that is old and brittle.
          Both are great ideas. I never thought of rock auto. I haven't had time to go to the local yard. Ima check their site to see what they got and maybe go before work tomorrow.
          Thanks!
          '93 T-bird
          '03 Silverado ECSB
          Missed:
          '88 Mark VII
          '86 CV
