looking for a proportioning valve for 1985 vic, the one off the master cylinder
Proportioning valve
Proportioning valve
WARNING: Above advise is based on actual experience or just plain common sense. In the event said advise is determined to be incorrect you are entitled to a full refund of exactly what you paid for it.lol
85 LTD Crown Vic Coupe 302 CFI Dual Exhaust No Cats Thrush Welds
pwr windows, locks, seat, antenna
cruise, tilt, white on white, maroon interiorTags: None
I have 1 for a 91 in very good shape if its that same as the 85's. Should be since its the old style booster and mc and rear drums. $10 and shes yours if you want er.
thanks, andyFinally have an on the books porting/custom fab business!
