Hi there, was wondering if someone would take pity on me and sell me a fuel injection system for my 351 Windsor 2 barrel carbeurator engine relatively cheap?
351W Fool Injection System
For a panther? I assume your looking for the lightning system then, since that is supposedly the only intake that will fit under the hood of a panther without having to modify the hood. (save expensive aftermarket intakes). you can get truck ones...but you'll have to cut into the hood. You may be already aware of all this...just wanted to relay theinfo-Phil
I have a ported 351 truck lower with BC Bronco's intake adapter to allow a stock 5.0 HO upper plenum to go on...and will clear your hood with room to spare, you're on your own for injectors, fuel rail, upper plenum and everything else though. Let me know if you're interested.
-Don'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by Brown_Muscle View PostFor a panther? I assume your looking for the lightning system then, since that is supposedly the only intake that will fit under the hood of a panther without having to modify the hood. (save expensive aftermarket intakes). you can get truck ones...but you'll have to cut into the hood. You may be already aware of all this...just wanted to relay theinfo
I'd let it go for $200 shipped and I will clean it up and even give it a fresh coat of black or Ford Grey engine paint if you'd like.
Originally posted by Mike_Windsor View PostYes, I think I read this elsewhere. A "lightning" system.
i have a ho upper plenum, fuel rails (will need minor mods to fit the 351w lower) 65mm throttle body, and either 19 or 24 lb injectors, you will need an efi wiring harness, a maf ecm from a 89-93 mustang, a maf meter and harness and mostlikely a tune to make it run right
I could sing a tune to it no problem. Well, actually, I have no musical ability whatsoever, but you know.
What the heck is a "ho" anyways? And no I don't mean a sexually promiscuous woman.
I just had a fight with my girlfriend about money, she wants a Nintendo DS 3D or some crap and I want, well, this stuff. $200 seems reasonable.
Lincolnmania, how much did you want for your parts?
ho is H.O. short for High Output, the intake came off of a mustang or mark VII, it flows better than the stock 5.0L intake that came on boxes.-Phil
